Hi guys,
yesterday big rain caught me. Right in front of my house curvy started to work bad and fire from exhaust, and become SV325...
I turned her off immediately, and I knew that problem is water on front spark plug. After drying everything with fan, she woke up again.
So - I've read that best protection for this case is - front fender extender, better spark plug cap, and periodically cleaning the drain hole.
My question is - what is the best way to clean the hole?
Is it safe to blow it with compressor (put compressor pipe on the lower drain hole and blow)?
I tried with plastic zip tie but it stuck somewhere after 3-4 centimeters...
And second question - if I'm getting right, that drain hole is nothing but 'path' from top of cylinder to its lower side, used just to take the water from spark area?
